DXV Codec not appearing in Quicktime
craftycurate
Post by craftycurate »
Has anyone managed to get the DXV codec to appear in Quicktime (v7.6, XP Pro)? It doesn't appear as a codec option when I export as Quicktime Movie. Nor does it appear as an option in my video editing package which can export in Quicktime format.
craftycurate
Re: DXV Codec not appearing in Quicktime
I know what the problem was ... I had Quicktime installed in a non-standard directory, and the Resolume installer must have assumed it was installed in the default directory.
I reinstalled QT in the default directory and now DXV appears in the list.
On PC this file: DXVWindows.qtx
Should be in this folder: Program Files/QuickTime/QTSystem/
On Mac this file: DXVCodec.component
Should be in this folder: /Library/QuickTime/
