Midi Yoke on Vista
Midi Yoke on Vista
I want control Resolume from Ableton. I believe I need something to create virtual Midi ports. Midi Yoke doesn't appear to run on Vista. Can anyone recommend any alternatives. Regards, Chris.
						Re: Midi Yoke on Vista
MIDIyoke will run on Vista, but before you install you need to disable the Windows Vista UAC settings...  Otherwise the installer will not run properly!
-Launch MSCONFIG from the Run menu.
-Click on the Tools tab. Scroll down till you find "Disable UAC" . Click on that line.
-Press the Launch button. (A CMD window will open. When the command is done, you can close the window.)
-Close MSCONFIG. You need to reboot the computer for changes to apply !!
Now you can install MIDIyoke !
After installing MIDIyoke repeat the steps above but then choose "Enable UAC"
Do not forget to restart after disabling/enabling UAC!!!
