Hi all,
I'm working on a setup for a multi-screen project. I have 4 of the new Mac mini's with 4GB of RAM. Each unit will drive it's own HD projector. I'd like to know if it's possible to control all of these units frame-accurately using Resolume on each of the machines?
Could this be done with one midi-device shared across all the machines? If so would this be frame accurate?
Any comments or pointers would be most appreciated.
Cheers.
Control Multiple units running Resolume?
- gpvillamil
Re: Control Multiple units running Resolume?
Resolume 3 implements excellent OpenSoundControl controls.
There is a tutorial with examples on this forum.
OSC would give you higher presentation and greater speed than MIDI.
I would say it is definitely do-able with OSC!
(Also check to see if the license terms allow you to run 4x computers...
