4 screen technique?
sburke1
4 screen technique?
Post by sburke1 »
Hello, right now I have no video mixer. I want to be able to trigger 4 clips, and then easily, send them to the four corners of the screen. It would be ideal if this was just one button. I am starting to get decent results with link knobs on x and y position and a lot of hassle, is there a free frame effect or something that will do this quiclky though? Does anybody have any tips to the easiest way to acheive this in r3?
VJair
Re: 4 screen technique?
Post by VJair »
make sure all the clips are the same intial size.
use 4 layers, on the settings for each layer, pan / zoom accordingly ( so layer 1 is positioned in the top left, layer 2 in the top right and so on )
load the clips into avenue, making sure that the 4 clips you want onscreen at the same time are in a vertical column
press the column number above the clips ( right at the top )
sburke1
Post by sburke1 »
Ive got that down, I'm looking for a easy/sleek way to do this though. I want to be able to trigger a clip full screen, then easily send it to the corner. I dont want to have to mess with fine positioning at a gig. Even going through the time to map the zooms, position etc to link knobs is a drag. It would be VERY handy if each clip had a button that shrunk it down to a half, or corner(quarter).
