MIDI - RGB - RES3 problem
krallik
Post by krallik »
When i want to map ( midi or keyboard ) "RGB" channels switches, I'm able just to "turn on" them .. but .. there is no way to "turn off" the channel with the same button ( like res2 ). Is there any solution for it .. or it is a bug?
Re: MIDI - RGB - RES3 problem
Yes you found a new bug, I now have the same problem here too. We,ll fix it. Thank you for reporting it.
