i have macbook pro 15'
3.06GHz Intel Core 2 Duo
4GB 1066MHz DDR3 SDRAM - 2x2GB
500GB Serial ATA Drive @ 7200 rpm
os x snow leopard 10.6
i have a pretty big composition on resolume 3.1.3:
4 layers with about 300 clips anywhere between 1 second and 10 minutes, all renderd with the dxv codec and all have hue, mirror and brightness&contrast effects.
when i play all 4 layers on my macbook pro, i get decent FPS of about 40-45.
but when i connect to a projector (either using a scan converter, or mini display port to VGA), the FPS drops down to about 20-25
- is there any way to increase the FPS?
- if i partition my harddisk and only install resolume on it, will it help?
- i heard that the software Gameboost can help increase FPS, but it's not compatibale with os x, do you know of a software that is?
any helps or tips will be appreciated,
Thanks! naddyd
