hi,
I just wanted to ask, if in resolume avenue you can map a button to change the layers opacity mode. Like from normal to bpm and vice versa..
Midi mapping
Re: Midi mapping
Hey there
Unfortunately this feature is not supported. Maybe having two copies of the clips with different settings for the opacity slider gets the result your after?
oblivionrpg
Re: Midi mapping
Yep, that will do the trick...
