Nobody responded to my last post so I am throwing the question out there again.
Does anyone know of a hardware controller, midi controller, or video mixer controller, that is compatible with Resolume 3?
This is the last question I need answered before I buy.
MJ
Hardware Controller...........
Re: Hardware Controller...........
Pretty much every MIDI controller that you can plug into a computer will be compatible (either directly via USB or with the help of a MIDI interface)
There is no "Resolume Avenue Controller" specifically designed for the programm itself, so it's basically a matter of how you want to use Resolume, what parameters you want to control with your MIDI device and finding a controller that suits your needs.
Then you can assign the controls within the program as you like, so basically it doesn't matter that much what MIDI controller you are getting - as long as its layouts and controls work fine for you.
Don't know if it's that what you meant, but maybe it answers your question.
