I'm a newbie with Resolume 3.1.3 on Windoze XP using MacBook Pro Bootcamp.  I want to mix in a folder of JPEGs during a set. I read in forum posts that you can drag folder or multiple JPEGs on to a channel and it will create a single photo sequence that can be controlled by the speed slider.
I've tried this but it spreads photo out to other clips in layer.
Is it possible to do this in version 3?
If not, do you have suggestions for 3rd party  software?
Thanks much!
						How to cycle through folder of JPEGs
Re: How to cycle through folder of JPEGs
as far as i know this photo-sequences don't work (but can maybe built in, would be very nice!)
i would do the work before in an video-cut application!
should also work on virtual dub which is 4free
Hey Ronsky!
This is a feature of R2, which unfortunately is not available on R3. There are a few workarounds, among others the flash file mentioned in this thread on VJForums.com: http://vjforums.com/showthread.php?p=242586#post242586.
Hope that answers your question!
