Quartz playback freezing
suzybee
Post by suzybee »
Hi gang,
I'm really happy about the new Quartz aspect of Resolume! :D
I have had a recurring problem though: while playing Quartz compositions in Resolume, the playback occasionally freezes unexpectedly and I can't seem to get it moving again.
So i've had to re-load the quartz files which means i lose my clip settings, and would be bad news in a live situation.
Has anyone else had this problem?... :roll:
Cheers,
Suzybee ;)
Re: Quartz playback freezing
We have seen this happen when you appty the Wave Warp effect. Perhaps you used that?
suzybee
Post by suzybee »
Hi Bart,
Hmm, I haven't been using wave warp...
It could be something to do with overloading the program/laptop, and it has happened when i've been messing about with lost of parameters when i'm setting up my deck, but it has also happened when i've only had 2 layers going and no effects on the go. :roll:
I'll try mucking about with the quartz files you guys provided to see if it's just the ones i've made which are freezing. It's a fairly random problem so it's difficult to see the cause.
I'll post again when i can give more specific information about the circumstances when it occurs.
Thanks for getting back to me,
Laterz,
Suzybee :P
