Hi
i'm using ableton live to mix audio. What i love is when i play a new scene all the previous clip are stopping excepted the thumbail whitout stop boutton. I think i'll be a good thing if we can do that in resolume.
For example when i play the first column i have 3 layer which are playing. when i play the second column only the first and the third layers are something load and nothing on the second. In this way, the second layer of the first column is still playing.
Regard.
clip still running when nothing is on the next column
- Tschoepler
Re: clip still running when nothing is on the next column
funny, I was thinkin about a switch button (comp settings) for this just the other night.
+1
+1
Don't forget that other people may actually want to clear the layer as well, all within the same composition. I guess a way that this could be implemented quite easily is to have a 'stop' clip in there when you do want to clear the layer.
We're looking into clip and column sequencing at the moment, so I'll add this as a request.
- olivepixel
Also think this would be great; much better to have a stop clip than to have to duplicate a background clip on every column to make triggering columns usable!
