Hi
I cannot get normal output on Display 2 in either R3.2 or 3.3.
If I select Full Screen then Display 2 is black.
If I select Windowed mode, then nothing appears until I drag the window any distance in any direction, but then it appears stuck in a 5 frame loop or thereabouts. It gets wierder.
If I now drag the Windowed display so that it overlaps the laptop screen and Display 2 (the extended desktop), the output plays normally, but if I then drag the display window back so it is fully in Display 2 (the extended desktop), it goes back into the 5 frame stutter thing.
I have to go back to R3.1.3 for it to work properly.
I really need to get this fixed because I've got a live show in 2 weeks.
Any suggestions?
Cheers
Richard
3.2\3.3 Display 2 Wierdness
Re: 3.2\3.3 Display 2 Wierdness
UPDATE: I've fixed it by setting NVidia 3D settings to "Compatibility Display Mode" but I didn't think this was necessary any more?
