I think it would be handy to have some form of clip sequencing so that when recording a showreel (for example) you could get clips triggering precisely.
I expect this is fairly easy, and I imagine the best way would be to use a basic MIDI sequencer to send signals to Resolume, but I have no idea where to begin. Does MIDI need to come from an external source, or can it come from a program running on the same PC? Has anyone tried this kind of thing and if so what do you suggest?
Sequencing clips for recording
- olivepixel
Re: Sequencing clips for recording
Ahha!
Seems this is what I was looking for:
http://www.resolume.com/avenue/manual/tutorial_live.php
Now I just need to work out how to sequence for a long track in live.
