Hi
I'm having problems getting several audio loops to beat snap accurately. This seems to run fine when everything is in the same column but when I try to switch to another column running a similar setup or even sometimes just changing one audio loop for one from a different column, the beat snap gives an awkward latency throwing it out of sync. It doesn't always do it, but enough to make a live set with audio out of the question. It doesn't seem to make a difference how many audio loops are running. Ideally I'd like to run 4 or 5 simultaneously (bassline, beats, guitar loops, etc.) with a two or three video clips and be able to chop and change seamlessly. I am using 44.1khz 16 bit wavs on a Macbook pro with a decent audio interface.
Beat snap not very snappy
Re: Beat snap not very snappy
Hey BankOfCaligula
I'm sorry to hear Resolume is not quite working out for you. We dedicated a lot of time to get quantization functioning correctly, but if you found an issue, we'd love to look into it. Could you perhaps send us a recording so we can see what's happening? And also it would be a great help to have your logfile so we can see what your hardware setup is like!
BankofCaligula
Sorted. Now running the audio from Ableton. Everything is now running smoothly. My life is complete!
