Addons - Modules
Basic
Addons - Modules
Post by Basic »
Just read the last post about eyesupply and there 'custom' resolume. Will there be some support in the future for peeps to write there own like addon's on like in modul8 modules?
Cheers :idea:
Re: Addons - Modules
The custom Resolume we made for Eyesupply mostly has to do with the computer they use to run it on (which is a beast). There are few functions added especially as well, which most likely will make their way to the 'normal' version in some form sooner or later.
We're not planning to add support for a plugin system, but it's always been possible to write your own modules using Max.
dbassix
Post by dbassix »
Max? What do u mean with this?
Basic
Post by Basic »
Ah i see... i forgot about max :) Thanks.
Max/MSP. http://cycling74.com/. For instance the co-pilot add-on was made with Max: http://www.resolume.com/forum/viewtopic.php?t=5239
