1050x10680 aviable?
1050x10680 aviable?
Hello im newcomer in resolume. I want to know, does the resolume allow to play on output 1680x1050 resolution files? Reasonebly to compress files to this resolution? Thank you for your help.
- Stickygreen
Re: 1050x10680 aviable?
1680x1050 yes, just select composition then settings, and type in your custom resolution. but if your title of this thread is the correct resolution your looking for 1050x10680 then i doubt it, thats probably to large.
