hello everyone
If i developp a freeframe GL effect for the windows version of avenue , is it the same to use ( the dll) in mac version or need to make another developpement ? if yes is it easy?
thanks
laurent
freeframe for mac version
Re: freeframe for mac version
If you don't use any (windows) platform specific libraries - and usually there is no reason to do so - you can just compile the code on OSX to build a .bundle which is the equivalent to the .dll, but you can't just copy the .dll to the Mac.
