problem with VisionRGB-E2s Video Capture Card in R 3,3,2
svoboda
Post by svoboda »
Hello, I'd like to report a problem. I bought graphic (video capture card) made by Datapath - VISION RGB E2S PCI that runs stable in Windows 7 64 bit. It runs fine without glitches in Arkaos program but in Resolume 3.3.2 it is being detected but these problems occurs:
- if card works in video-in mode, video that is grabbed is poor quality, Resolume definitely lowers video quality.
- card works for only about 20 seconds, after that it hangs up and stops responding, Resolume doesn't detect it further even arter Resolume restart
card info: http://www.datapath.co.uk/products/vide ... ionrgb-e2s
svoboda
Re: problem with VisionRGB-E2s Video Capture Card in R 3,3,2
Post by svoboda »
problem does not occur in ArKaos Grand VJ, Arkaos MM
