Record function without applyed effect
GuruMeditation
Post by GuruMeditation »
The record button on res avenue is very useful for sampling.
But... I currently have a big problem : I use the keystone plugin on my composition, and when I record a loop, the keystone is recorded too. So when I put the recorded loop in my global mix, I have the recorded loop with original keystone AND the composition keystone active : the keystone is applyed twice and result : the recorded video does not fit to the screen.
So, a simple option with the record function wich allow to record only video without effect will be great !
What do you think about it ?
HerrNieDa
Re: Record function without applyed effect
Post by HerrNieDa »
for multiscreen setups it would be fine to have output-functions like in resolume 2 (all layers with/without global effects, and also single layers)
and also had a though about multiple audio output streams (for a-v installations for example)
don't know if it makes sense for coding such things but now i got it off my soul :)
