Using OSC to change BPM - bug
gpvillamil
Post by gpvillamil »
So I'm trying out the possibility of using one instance of Resolume 4 to control one on another computer via OSC, and it seems to be working fine, except for this:
When I change the BPM on the "master" computer, the BPM on the "slave" immediately goes to 500.
The "master" is a Macbook Pro on OS X, the "slave" is running Windows 7. The same behavior also happens when going the other way, from Win 7 to OS X.
I haven't looked at it with an OSC debugger yet, but I think you are actually sending the BPM value, not a float between 0.0 and 1.0
gpvillamil
Re: Using OSC to change BPM - bug confirmed
Yep, confirmed.
Resolume is sending this when you change the BPM:
print: /playbackcontroller/bpm 121.
but it is EXPECTING to receive a float scaled from 0.0 to 1.0
Pls fix this, kthxbye.
Thanks for the find! Ticket made!
