midi interfacing between a pc and macbook pro...
benjwalsh
Post by benjwalsh »
can i maybe get a usb to usb cable to control resolume on my mac via midi on my pc ?
Re: midi interfacing between a pc and macbook pro...
USB to USB is not possible I think!
But this post should help you.... LINKY!!
What you also can do is to control via artnet!
Greetz
I'd probably go for MidiOverLan, and connect them via an ethernet cable. You can download the great rtpMidi tools for PC here: http://www.tobias-erichsen.de/rtpMIDI.html. OSX has this tool built-in.
benjwalsh
Post by benjwalsh »
is there any other way don't really want to tie up my either net port ..
read above! :mrgreen:
greets
VJair
Post by VJair »
what else do you need to use your ethernet port for whilst performing?
ultravox
Post by ultravox »
Hello all,
I know it's an old post... but if my answer can still help somebody... ;)
If you search a reliable and free solution to connect all yours computers together: http://www.copperlan.org
100% compatible with MACOSX, WIN, your USB MIDI interface and all your softwares
I have a couple of MIDI interface AL88 from http://www.alyseum.com to connect all my synthesizers, amazing! :D
I used it, very simple and fast, real plug&play :)
It's a global solution for my studio :mrgreen:
