DXV thumbnails in windows
pleasuretek
Post by pleasuretek »
I am looking for help in making my DXV encoded footage show a thumbnail in Windows. Its really hard to organize clips when I cant see them. I see DXV thumbnails in resolume fine, and the files play fine.. My issue is with windows (7 x64), most .mov files I can see thumbnails for (I have gone into registry and added a key to .mov to make .mov thumbnail) , but anything encoded with DXV has no thumbnail.
Anyone know a way I can get thumbs of these clips? I tend to stay away from 'codec packs' but if that might help then I am open to suggestions.
Asus build - intel 2.8GHz T9600, 4GB 800Mhz DDR2, ATI 4670
Rack unit - intel 2.7GHz q6600, 8GB 1066Mhz DDR2, 9800GTX+, intensity HDMI input card
Godzil
Re: DXV thumbnails in windows
Post by Godzil »
pleasuretek wrote:Anyone know a way I can get thumbs of these clips?
http://www.xnview.com/
pleasuretek
thanks, it works. I can't see them in explorer, but I can browse and reorganize using this program. Thanks
Sadler
Post by Sadler »
Google Picasa also allows you to see DXV thumbnails (inside the program).
