Hello guys. I am having some issues connecting my newly built controller for Resolume 4. I have tried everything that I can think of with no success. I was wondering if someone could take a look at my file and see if I have done anything wrong, which I think I have. Any help would be gladly appreciated.
Below is a link to download my touchOSC file. EVERYONE is welcome to download. I know, it is excessive, just having fun.
https://files.me.com/mjtimothyscott/we3osl
Resolume 4/TouchOSC Connection Issue
Re: Resolume 4/TouchOSC Connection Issue
hey,
I cannot download the layout to the iPad (Timeout) - Seems that the whole .touchosc layout is somehow corrupt?! - Other layouts work fine. Hope that helps.
Do you use any man-in-the-middle software as some OSC messages in your layout are not Resolume native?
cheers,
Rene
cheers,
Rene
I am having problems also... my touch o/c patch works fine with two others softwares but Avenue 4.1 doesn't pick it up.
Ive turned OSC output on/off, I've turned bundles on/off, I've tried via normal wifi and an Adhoc.
ReggieUnderground
Under Resolume 4.1 I get constant crashing with TouchOSC on iPad3. I was chalking it up to the iOS app but perhaps there is something else going on with OSC at the Resolume end. /2cents
Thanks for your 2 cents Reggie, but this does not really contribute to addressing any of the problems in the thread. If you want us to look into your crashes, please email us with more details about your setup.
