Composition / Layer replicate
vjkatza
Post by vjkatza »
Hi, as i'm stepping forward for replacing my VJ software to resolume, I have an important question.
is there an effect / solution for tile/"mirror tile" in resolume?
"Tile" effect doesn't solve it and I need something to control in realtime.
(Duplicating layers is not an option)
(in Other software: "mirror effect" / "Video split effect"
I attached desired image example:
ORIGINAL VIDEO
DESIRED EFFECT
10x and a Happy New Year to All of you!!
HerrNieDa
Re: Composition / Layer replicate
Post by HerrNieDa »
well such an effect is not available... but you can try to combine effects, the Tile and the Mirror Effect should do it. If you don't get what you want, maybe download fparameters ffgl plugin for more options! (if you position/scale the layer and want to mirror, you may have to use add mode with 50% on the mirror effect for example)
vjkatza
Post by vjkatza »
This is strange...
This is a very basic feature with other software...
vjkatza
Post by vjkatza »
I've downloaded the IR MAPIO demo,
I succeeded achieving this with it :)
But a more easy effect is needed....
HerrNieDa
Post by HerrNieDa »
try to combine fparameter and mirror effect to get result 3
result 2 you can do with tile alone
result 1 with tile and slide effect
okay, this way you have to combine 2-3 effects for this... but you can also save the preset of the effect so you have to do the adjustment only 1 time!
and the workflow should be at least as fast as in irmapio ;)
vjkatza
Post by vjkatza »
10x I Will Try That!
