Resolume 4.00/4.01 & APC40 midi-out-knob-problem
shoooooooorty
Post by shoooooooorty »
Hi Resolume :)
i mapped
-the in/out pins from the timeline
-the scale function from the clip/transform
to my apc40 knobs.
everything is running smooth like in 3.3.2
Until i open the midi settings and turn the "midi out" function on. The Knob leds getting crazy and i cannot scale/shift anymore.
i love the midi out function, but midi out hates the apc40 knobs?
Shorties
Re: Resolume 4.00/4.01 & APC40 midi-out-knob-problem
Post by Shorties »
By crazy what do you mean? Like does it shoot back and forth between maximum and minimum ranges? Cause I have had that issue with linking my knobs on my APC 40 with the transport.
yugpmoc
Post by yugpmoc »
Same here. I feel like I'm missing somthing simple, but I've been trying to link the knobs to position and scale and things like that to no avail. Things slam over to the max or min and stay there. Somebody throw me a bone.
There are some issues with midi out, which will be fixed in the 4.1 update....
Kaizen
Post by Kaizen »
Has this been fixed in 4.1 ?
I'm considering getting an APC40 to control Resolume and I really need knobs to keep track of what position they were in when I switch layers, for example:
I would like one knob mapped to Active Layer clip speed control, and when I switch focus to another layer, I would like the same knob to reset to the value of the currently actively layer without a "jump" between speed values of the two layers.
Please advise, thanks!
What you describe has never been an issue and has always worked as expected in all versions of Resolume 4.x.
In other words, you can safely purchase the APC 40 :)
