I would like to use the QC patch that was written for CoGe called CoGePSBrushes. Is this possible? I downloaded the patch, and opened it in QC, but I cannot find how to get the .abr files into QC or how that input gets into QC. The video found here on Vimeo, is hard to see. Opening the patch, I get this message that the QC composition was not restored properly it appears to be referring to CoGe, which of course I am not using. Is this because it is designed to look for CoGe input only? Any help on this would be appreciated.
> (null)
<QCNodeManager | namespace = "com.apple.QuartzComposer" | 491 nodes>: Patch with name "QCPlugInPatch:CoGePSBrushesPlugIn" is missing
> Render in Image
Cannot create node of class "QCPlugInPatch" and identifier "CoGePSBrushesPlugIn"
> Render in Image
Cannot create connection from ["outputArray" @ "PlugInPatch_CoGePSBrushesPlugIn_1"] to ["inputStructure" @ "StructureCount_1"]
> Render in Image
Cannot create connection from ["outputArray" @ "PlugInPatch_CoGePSBrushesPlugIn_1"] to ["inputStructure" @ "StructureMember_index_1"]
> Render in Image
Cannot publish input port ["inputPath" @ "PlugInPatch_CoGePSBrushesPlugIn_1"]
> Macro Patch
State restoration failed on node "RenderInImage_1" <QCRenderInImage = 0x15b9a000 "(null)">
> (null)
State restoration failed on <QCPatch = 0x509490 "(null)">
QC patch brushes for .abr files
Re: QC patch brushes for .abr files
This is not really a Resolume issue, it looks like the plugin is not installed correctly, since QC cannot load it.
