Hey,
I've been searching and searching to find a solution to this, to no avail.
basically, when I set the BPM clock to - for example - 130BPM, I assume it should count 4 beats (go around the square thing once) in slightly less than two seconds. However, what I'm experiencing is it takes about 20 seconds or so to go around once. However, when I receive midi clock data from Traktor or Live 8, it works perfectly (although the BPM looks like it goes crazy). Any ideas? Computer slowness shouldn't be an issue.
Thanks,
- Llamasquishy
Global BPM Clock Slow
Re: Global BPM Clock Slow
We need more info to help you... Goto10 (Resolume support) write this a few weeks ago:
"Only if you can't find your problem on the forum, create a new topic. When creating a new topic, please provide the necessary info on your hardware and software setup (operating system, graphic card, Resolume version, codec and filetypes used). Most importantly, be as clear as possible in describing your issue. The problem may be as clear as day to you, but if we need to guess at what's happening, it becomes very hard to help you. A good way to report a problem is to outline it in simple steps we can follow, and tell us where it's going wrong."
an old bug
delete the preferences.xml (in your User/Documents/Resolume folder)
restart resolume
select an audio decive/soundcard, otherwise bpm doesn't work at all
restart resolume
Llamasquishy
Thanks. I just deleted all my preferences and stuff, which seemed to fix it for the time being.HerrNieDa wrote:an old bug
restart resolume
