I am using two layers with similar clips playing on top of each other so I can cue an overlay or play with the opacity of the two.
The master controls are great, but over time (regardless that these clips are the exact same length) they fall out of sync.
I imagine it has to do with Resolume always trying to play at the fastest fps and not a consistent one. Eventually leading to one of clips being faster or slower than the other.
Right now my work around is setting a midi key to cue both the clips at the same time so they restart in sync...
Is there a way to lock two clips on separate layers so that they stay perfectly in sync?
Thanks in advance.
