Hey guys
Just a little bug in the latest Arena version (disovered it quite some time ago, was probably in earlier versions as well .. sorry for the late report):
Set a Layer to Auto Transitions of i.e. 1 sec length, have a clip running that is set to Play Once. Than click on a second clip on that layer. The transition is done as expected, but as it finishes both clips get stopped, the Layer is cleared.
Hope you can fix it,
thanks and bests,
Marcel
Minor Bug: Autotransition + PlayOnce kill both clips
Re: Minor Bug: Autotransition + PlayOnce kill both clips
Looks like that when the outgoing clip is ejected before the transition is complete, both clips get ejected. Thanks for letting us know.
This is still not fixed in Arena 4.1 ?!
This bug is part of the clip connect code of Resolume. This is besides playback probably the most important piece of code in Resolume. When we make changes there, we risk breaking everything. So to be on the safe side for the 4.1 release we moved this to 4.2. It is set to the highest priority though.
okay, sounds reasonable. thanks.
