Hi
first sorry for my poor english.
I'm using resolume 3 for an educational project on a small I3m laptop withe windows 7.everything works fine.no videos here , just pictures ( 640X480) .I'm trying the same project with the resolume 4 demo and have an issue with the auto layer transitions. during the transitions, there is an huge cpu spike and the fps falls from 60 to 20. I can see that too with dvx movies, but there is a much smaller differences. all problems disapears if I don't use the auto layer transitions ( like resolume 3).I think that there is more fps fall and cpu spike with an main outpout of 640X480 than 1024 x768 for the same pictures , and of course better are the resolution of the pictures , higher are the cpu spikes and the fps fall.
so here is my questions :
is it possible to have a less cpu hungry layer transitions ?
I suppose than picture compression are like videos with codecs, so witch could be the lighter format ( jpeg or
png) ?
thanks for reading
Damien
pictures format and layers transitions cpu spike
damstraversaz
digital arts:
http://www.damientraversaz.com/#!art-numerique/c1s43
music for dance, documentary and digital arts:
Re: pictures format and layers transitions cpu spike
Strangely enough, the cpu should hardly be used on layer transitions. Can you contact us with your logfile so we can take a look at your computer configuration?
damstraversaz
thanks a lot for the answer, I'm in hollidays now, I will send you the log file as soon a possible
digital arts:
i3m...
If i checked in the right place (wikipedia) it has an integrated gpu...
- could this possibly be the source of the trouble?
damstraversaz
you're right ? it has an integrated gpu. I will check that point
digital arts:
