In update 4.1.0 you '[FIXED] OSC /activeclip/quicklook/0 does not turn quick look off'
but it seems to be still toggling. In 4.1.0 and 4.1.1 if quicklook is turned on (klick on the icon in the user interface) and then /activeclip/quicklook/1 is sent, it is turned off and vice-versa.
OSC quicklook toggling instead of on/off
Re: OSC quicklook toggling instead of on/off
But we did what you asked! Quicklook/0 does turn it off doesn't it? You never said you wanted it to stop toggling as well!
PLEASE!!!
What do you smoke over there in Amsterdam?
If I push the off button on my Lemur, Resolume has to shut that f* quicklook off, and if it's not on, it should stay off. I'm off.
