Old resolume compression RLE.avi, how to convert it ?
kratata
Post by kratata »
For a early version of Resolume, it was recommended to use a compression which my computer now calls : MICROSOFT RLE.avi ( the original compressionname i do not know anymore ... i suppose it was in Windows 2008 ) In your manual you recommended this compression.
Anyway.
I dug up my old loops for a project, and After effects & MPEG streamclip do not play it.
I need to edit them in After effects, how to convert them to useable files with a program which will play it ?
Cant seem to find a way...
Thank in advance.
Krista !
No Knowledge is a Statement
HerrNieDa
Re: Old resolume compression RLE.avi, how to convert it ?
Post by HerrNieDa »
you should install a codec, just found a codec pack in google http://www.free-codecs.com/download/ace ... s_pack.htm
if the media isn't still supported may you have luck with other programs like "Super" http://www.chip.de/downloads/SUPER-2012_17370353.html
kratata
Post by kratata »
thanks. I will give that a try.
But i am not going to install all those codecs, than my machine will start to cry anyway.
Does anyone know the original name of the compression/codec that was advised by resolume in the first versions ?
Could it be Indeo? Indeo used to be pretty good, but they dropped support for it on Win 7.
kratata
Post by kratata »
YESSSS it was indeo !!
Thanks ...
does Apple support it ??
then i could convert it on a mac somewhere ...
yochee
Post by yochee »
check the ligos website here with some explanation why Indeo is missing on win7 and osx: http://ligos.com/index.php/home/support/indeosupport/
you can run a virtual machine with xp if you have Win7 pro ;)
And to make it work on Apple you'd need OS9. Which pretty much comes down to: No it doesn't work on Apple.
