Wishlist Advanced Output
movebandit
Post by movebandit »
Heres my little Wishlist for the Advanced Output:
-Less than 4 points in input (for Triangles)
-Undo Function
-Use .png Files as Mask
-Merge several Masks / Crops to One
-Preview ZOOM (Pleasepleasplease)
-Smaller White Dots in Main Output when Displaying slice info
-White cursor Cross (like in Madmapper)
-Slice Bypass Midi/DMX switchable or a little Sequencer
....next whishes follow soon...
movebandit
Re: Wishlist Advanced Output
Finer Rotation. Not only in 1 Deg Steps....
movebandit
No Reaction ?...ok another one: Fade between 2 Presets ( Live Slice Transormation)
If the purpose of your post is to hear our standpoint or progress on these features, most of them have been discusses before. If you have a specific one that you cannot find by searching the forum, I'll be glad to give some insight on it.
If you want +1s, here you go:
+1.
Alvis_Cortex
Post by Alvis_Cortex »
+1
martino.cerati
Post by martino.cerati »
+1
