I have to do some gigs coming week VJ'ing on a circular screen, now I've tried the bezier circle in the advanced output module of Arena (4.0.1) but when I send circles or rounded forms to the output the image is really distorted, and there is no way I can adjust that by hand using the points in the slice
Besides, I can't scale it up or down if the circle would be to big, or to small for the screen, so next try was creating a PNG with a transparent hole in the middle put it in a separate layer with the opacity setting on "dodge" this works rather nicely but when I use my FX the layer is obsolete and the whole screen is used, not just the circular area
So then the brilliant Idea came to look if I can use my PNG in the advanced output module so the main output has to go thru my PNG and everything outside the circle is invisible, but this doesn't seems to exist.by now I'm starting to get worried because my ideas on "how to" are drying up...
So anyone who has done this before, or has ideas how to make this work?
I would be very, very gratefull!
