Windows 8 Support
Windows 8 Support
what about win 8, are there any known problems or infos to know?
| EVGA SR-2 | 2 x Intel Core i7 X5650 | 48 GB Corsiar DDR3 PC12800 | 2 x HD5870 Eyefinity 6 | 1 x GTX580 | 256GB Samsung 840 PRO | 160GB Intel Postville | Win 7 X64 | Resolume Arena 4 |
Re: Windows 8 Support
I´m using it with windows 8 and the only problem I had is with the flash files.
Now I´m trying to downgrade to version 10.3, for the rest works like a chain for the moment.
but the softwate itself runs without probs?
your description sounds like a problem with Adobe/Flash-PlugIn.
I have a dell I5 8gb ram 1tb 10.000rpm HDD and ATI HD5654 and for the moment the only issue that i found is the problem with the Flash that crashes the application, I didn´t had time yet to downgrade the flash to version 10.3 but the aplication works fine On W7 i get 56fps and on W8 i get 60fps with 4 layers and clips of 800x600.
I´ll keep testing this weekend on a live and monday i can put some more comments
ok, maybe il try it, too
+1 on Flash problems with Win8. As soon as I try to load a file, boom, Arena crashes.
seems to be running nicely. getting 50-60 fps with 5 layers at 1920^1080.
windows 8 pro. all updates. upgraded from win 7 then used refresh windows option to revert it to a fresh install. upgrading over the top of the old install made for a very unstable windows indeed.
so far so good.
alienware m17x r4.
radeon 7970m with catalyst 12.10 drivers
no ssd.
so far so good.
alienware m17x r4.
no ssd.
+1 on flash problems with Win8
any news here?
I´m thinking about updating to Win 8
I got the same problem on windows 8 64 bit, my flash swf won't get loaded.
Could I have more technical details on what's happening?
