Whoops. In that case I stand thoroughly corrected.
I don't know of any controller that would allow such functionality.
Thinking out loud: What if you force your buttons to send CCs, and then limit the in and out points in Resolume?
Midi Controller that allows to enter a specific value?
Re: Midi Controller that allows to enter a specific value?
You could create a controller using http://vezerapp.hu/ on a Mac and control Resolume on either a PC or Mac via ethernet or WIFI the way vjcharm wants to by keying CC values.
You'd have to select the no-interpolation mode between keyframes to go from value to value without getting the in-between values.
