Nope. Thank you for the hint but at least on my rig it doesn't show thumbs. I tried even the full version with all the plug-ins and I consulted the support, but they don't have a solution, sigh! So I have to keep two formats of each clip ( dxv & sth else) to manage them efficiently, could be worseHe2neg wrote:Xn View is a good Solution for organise your libary... you can preview dxv and move it around as well..
R4 won't play clips!
beamUp-Art
Re: R4 won't play clips!
beamUp-Art
Hello Joris,Joris wrote: I'd be very, very surprised to hear you have the same problems when using DXV.
I replaced my clips in some compositions last week. While the problems named in the #1 post with H264-codecs came back, Resolume Av runs still stable ( and with good fps ~60) with your DXV-codec
So far, so good, but I noticed that the same clip rendered in any other codec than DXV runs more fluid. Mind you, that I played them also in the Quicktime-player to compare them. I could improve it by setting down the fps-Option in Adobe-premiere for rendering, but there is still a pulsating micro stuttering.
Is an improvement possible?
Thank you and best regards,
B
Comparing playback in Quicktime Player is not a good way to compare, since playback of DXV is only hardware accelerated in Resolume. In all other apps, it's a very heavy codec to playback on the CPU.
