have a few towers in the shop:
2x of these:
fractal design define r5 case
i7 6700k CPU
asus z170-a motherboard
coolermaster hyper 212 evo cooler
adata xpg 16gb ddr4 3200mhz ram
nvidia gtx 1070 8gb (zotac or EVGA) GPU
2x blackmagic decklink quad2 (16 SDI in/out) I/O
2x samsung 850 evo SATA SSD in raid-0
seasonic 850w 80+ gold modular PSU
windows 10
3x of these:
bitfenix prodigy m case
i7 4790k CPU
asus z97 maximum vii gene
16gb corsair vengence ddr3 1600mhz ram
2x asus nvidia GTX 760 2gb mini ITX (or just 1 if we swap the other card for a decklink I/O card)
3x 500gb sata SSD in raid-0
corsair hx850i psu
windows 7
1x of these:
xeon e5-1620v3
evga x99 motherboard
32gb ddr4 3200mhz
nvidia gtx 1080ti 11gb founders edition
3x blackmagic decklink quad2 (24 SDI in/out)
2x samsung 850 evo 1TB sata SSD in raid-0
seasonic 1000w 80+ platinum PSU
windows 10
2x of these:
fractal design define c
i7 8700k
gigabyte z370 motherboard
gskill ripjaws 16GB ddr4 3200mhz
(using old cards until GPU prices fall..) asus r9 390 strix 8gb gpu
2x samsung 850 evo 1TB sata raid-0
evga 750w 80+ gold PSU
windows 10
...think that's it!
POST YOUR GIG COMPUTER RIGS!
xdjxklusivex
Re: POST YOUR GIG COMPUTER RIGS!
What determines which rig goes to which event?admiralperpetual wrote:have a few towers in the shop:
2x of these:
i7 6700k CPU
windows 10
3x of these:
i7 4790k CPU
corsair hx850i psu
windows 7
1x of these:
xeon e5-1620v3
32gb ddr4 3200mhz
windows 10
2x of these:
i7 8700k
windows 10
...think that's it!
admiralperpetual
depends how many inputs/outputs are needed (and how many need to be the same system as there doesn't seem to be a perfect way to sync between systems still) and resolution/frame rate etc... for example can't do high refresh rates/low resolutions with the SDI cards so sometimes need to go VGA.. really any of the systems can get re-configured per-jobxdjxklusivex wrote:
Very nice set ups,admiralperpetual wrote:have a few towers in the shop:
2x of these:
i7 6700k CPU
windows 10
3x of these:
i7 4790k CPU
corsair hx850i psu
windows 7
1x of these:
xeon e5-1620v3
32gb ddr4 3200mhz
windows 10
2x of these:
i7 8700k
windows 10
...think that's it!
Which one would you recommend to use for capturing 2 Cameras HD, 2 Laptops for Powerpoint/Keynote 2 laptops with video images and sending a blend of 4 projectors or LED video wall inputs everything running on ARENA?
Im currently looking to build with the following:
ASUS Prime x99 Deluxe Motherboard
Intel CORE i9-7940X
Rijaws 64GB DDR4 3000MHZ
2x BlackMagic decklink quad2
NVIDIA GeForce GTX 1080 Ti
2x Samsung 960 EVO 1TB SSD
is this an overkill?
admiralperpetual
the biggest problem you'd run into is scaling from the inputs/outputs of the powerpoint/keynote laptops I think - have had some issues when feeding stuff like that from a mac mini via HDMI to SDI adapters into resolume then out of resolume to another SDI to HDMI converter to a monitor - if it's a lower resolution display (under 1080p) it's fine but if it's 1080p+ text/gradients can be weird. it's doable but just need to make sure everything is synced up settings wise, might need some better sdi2hdmi/hdmi2sdi scalers like a decimator md-hx for example. the camera feeds should be no issue though!KREATIVO wrote:Very nice set ups,admiralperpetual wrote:have a few towers in the shop:
2x of these:
i7 6700k CPU
windows 10
3x of these:
i7 4790k CPU
corsair hx850i psu
windows 7
1x of these:
xeon e5-1620v3
32gb ddr4 3200mhz
windows 10
2x of these:
i7 8700k
windows 10
...think that's it!
Intel CORE i9-7940X
the i9 is definitely overkill, though having more PCI-E lanes than the 8700k is nice when running 3 cards as you don't have any issues with the 2nd decklink not detecting sometimes. on the other hand clock speed is still king for CPU and resolume so getting those cores cranked up is a good idea..
Thanks for you input,admiralperpetual wrote:the biggest problem you'd run into is scaling from the inputs/outputs of the powerpoint/keynote laptops I think - have had some issues when feeding stuff like that from a mac mini via HDMI to SDI adapters into resolume then out of resolume to another SDI to HDMI converter to a monitor - if it's a lower resolution display (under 1080p) it's fine but if it's 1080p+ text/gradients can be weird. it's doable but just need to make sure everything is synced up settings wise, might need some better sdi2hdmi/hdmi2sdi scalers like a decimator md-hx for example. the camera feeds should be no issue though!KREATIVO wrote:Very nice set ups,admiralperpetual wrote:have a few towers in the shop:
2x of these:
i7 6700k CPU
windows 10
3x of these:
i7 4790k CPU
corsair hx850i psu
windows 7
1x of these:
xeon e5-1620v3
32gb ddr4 3200mhz
windows 10
2x of these:
i7 8700k
windows 10
...think that's it!
Intel CORE i9-7940X
I do own several decimaters md-hx which will be my hdmi to sdi to hdmi converters. Worst case I can just run my Roland v800 with the PowerPoint/keynote laptops and just send 1 signal to Resolume.
I’ll let you know how it goes.
xdjxklusivex
Why not skip all the HDMI/SDI conversion and go NDI? I have used it a few times and it works wonders.KREATIVO wrote:Thanks for you input,admiralperpetual wrote:the biggest problem you'd run into is scaling from the inputs/outputs of the powerpoint/keynote laptops I think - have had some issues when feeding stuff like that from a mac mini via HDMI to SDI adapters into resolume then out of resolume to another SDI to HDMI converter to a monitor - if it's a lower resolution display (under 1080p) it's fine but if it's 1080p+ text/gradients can be weird. it's doable but just need to make sure everything is synced up settings wise, might need some better sdi2hdmi/hdmi2sdi scalers like a decimator md-hx for example. the camera feeds should be no issue though!KREATIVO wrote:
Very nice set ups,
Intel CORE i9-7940X
I got a few min to kill ^^
I use a Fractal Node 202 case for travel because airlines.. It's for Resolume only. Built it weighs 14lbs. Same as my 2006 sli dell xps.
Uses:
Evga 1080ti ftw3
i3 7350k oc 4.5ghz 1151 socket
Asus z270I strix mobo mini itx
Corsair SF600 600w SFX psu
16 gigs gskill ddr4 3200 ram
2x Samsung 960 Evo m.2 500gb
Some corsair fans and a thermal right muscle heat sink I had to bust my but to find since its what I needed for the space limitations.
It doesn't sound too amazing but it works great for Resolume. Has more IO then a laptop. Good Wifi. More video outputs then a laptop. Some upgrade-ability unlike a laptop and a whole whole lot cheaper then most of your rigs.
Fits snug in this UDG trolly bag for travel. https://www.udggear.com/udg-ultimate-di ... nge-inside
Uses:
Evga 1080ti ftw3
xdjxklusivex
Digitrevx wrote: Fri Jun 15, 2018 01:54 I got a few min to kill ^^
Uses:
Evga 1080ti ftw3
Now thats nice!
