MacOS NDI optimisation - resolution degradation
Bassindaniel
Re: MacOS NDI optimisation - resolution degradation
Post by Bassindaniel »
The data transfer speeds was around 100-120 Mbps.
And yes. If I’m getting the pixelize issued ando internally
(NewTek ndi monitor).
Bassindaniel wrote: Wed Mar 25, 2020 13:31 The data transfer speeds was around 100-120 Mbps.
Was this NDI or file copy?
Bassindaniel wrote: Wed Mar 25, 2020 13:31 And yes. If I’m getting the pixelize issued ando internally
NDI monitor has an option in the Setting menu for Low Bandwidth, is that checked or unchecked?
Bassindaniel
Yes I did
Bassindaniel wrote: Wed Mar 25, 2020 15:32 Yes I did
You did what?
Bassindaniel
Sorry, Yes I did tried both checked and unchecked.
also, Please look at the attached file.
Daniel.
I think Newtek misunderstood you, based on their reply...
This happens for me on an older (2012) macbook too, but I need a really fast moving image for it, like a Static source. Doesn't happen however on any of my windows machines, though they are also more powerful.
Lowering the output resolution gets me back to full quality, maybe that would work for you too.
