Minrray UV430A ptz controls
resolumejunkie
Re: Minrray UV430A ptz controls
Post by resolumejunkie »
additional information:
https://forums.newtek.com/threads/absol ... rk.161366/
you’re talking about adding one word to your code
Or camera manufactures adding one line to their code? ;)
resolumejunkie
The fact that camera manufacturers haven’t bothered shows the insignificance of this software to them. Bam.
Absolute vs relative positioning is a whole different way to do things.
You can't recall a specific position of a camera by launching a clip, if you store relative positions movements in the clips.
If the order of the clips changes, the positions change. Should be pretty easy to understand this if you think about it a bit.
If you have a dedicated camera operator, go with the camera's ptz controls.
The fact that manufacturers don't implement a function according to specifications, shows the ignorance of the manufacturer regarding their own work.
Not thinking about the implications a bit, shows the ignorance on your side, and shows that you never used NDI PTZ with Resoulme, so not sure why you even comment about it.
resolumejunkie
Zoltan:
Resolume doesn’t support audio out via NDI, either. So you really don’t have a leg to stand on here, brother.
I have a Minnray PTZ camera and a Birddog PTZ camera. The PTZ controls on every other software I have ever used works with these cameras except Resolume.
Also, all other video software outputs audio via NDI.
Your hubris is suffocating, sir.
As I said previously, I have no hope for this software.
Everything is the customers fault with you guys….
Please don't spend time on something you have no hope for ;)
Locked
