Resolume Thoughts
rich_
Post by rich_ »
For my two pennys,
1) This package is clearly a production of pure quality. Nothing 'REALLY annoys/bugs' me, just greatful this shits out there.
So keep what makes it what it is, an unpretensous fast effecient reliable and great piece of software
However,
2)Either I missing a point or it'd be nice to see the ability dump an effect onto a clip with Midi input. Don't progam but seems that might be done using the Ctrl-Letter of selecting a clip and a midi note/controller in combination.
3)Prob a bit harder but, might be good to be able to 'bump' layers up and down. Like say, clearing layer one and then dropping layer 2->1 and 3->2 (whilst keeping they're settings) so you keep adding the new layer on the top. I know you get around this, just be cool to have.
4)Again not a biggy, but if it's not too much work to manage 2) similar thing could hold so that many of the controls used to edit the Active Layer edit the (Ctrl selected) layer with the blue highlighting. I'm saying this and wondering if I'm missing something-can you already do this?
5)The ability to load a deck such that it just fills in where the space is, or prob easy retains the positioning of each clip but only loads it if you've emptied that space. Just might help to move between decks more smoothly.
Like I say nothing to major, agree with 'some' earlier points, but you've heard them all already. Don't want to rant just though these improvements might be easier/new ideas to think about implementing.
If they're already in the program, pls let us know and then maybe the help manual could get a revamp?
Excuse the spellin-there's a dyslexic in the forum
Big Respect,
rich_
Post by rich_ »
Rich back,
OKAY so as for point five forget it-just found out you can select the clips that you want load or not load. So that solves the problem.
Lets get a forum running to let everyone into these things & link it to from the manual site-we don't want to distract you from that beautiful programing you do.
I'll a dummy run off but, it's clear that I don't no much so try to encourage some others; really would be of help.
Rich
