I have been using Resolume for the past weeks and I have some thoughts I would like to share. First I used an old PC, PIII 600, now I am using my new Dell Inspiron 5150, which I have reviewed in the Hardware section of VJ Central, BTW.
OK, my background is video, so I can't stand those dirty looking 320x240 clips. I am used to VJ with VHSs and DVDs, so image quality is an issue for me. That's why I have waited so much to get a notebook. The arrival of Freeframe plug-ins in Resolume, made me buy it and forced me to buy a new computer. The aim of this post would be to understand better how Resolume works, to better prepare my clips for it. I love the simplicity of Resolume, and the degree of control in some areas. The "animation-able" controls are great. Peter Warden's plug-ins are a god send. The general concept is very good. But I still think some aspects maybe improved... Let's go:
1) Speed of clips
My first doubt is at what speed does Resolume play clips?? I have arrived to the conclusion that it plays them as fast as it can, up to a point. Is this true?? I would love that when the speed is 25 (default) it respected the normal speed of the clip (x1). Even if it have to skip or repeat frames for this.
2) Reading clips
I have seen that even if it's playing two short loops (2x2Mb) it is always reading the Hard Disk. I can't understand this behaviour. It wouldn't be better to store clips in RAM??? Maybe long clips only store the first seconds in RAM or they read from HD the first time, but then remain in RAM to loop. But it seems stupid, now that RAM is cheap, not to use and abuse it to the max. It would save SO much hard disk life...
I understand that if you load a deck with 20x bif clips (400Mb each), this amounts 8Gb, impossible to load in less than ten minutes. But it should be great to have a Preferences control, where you can choose to load to RAM clips lesser than X Mb... (where you can choose the X!!!)
3) Quicktime and Flash
To develop software that must be compatible with other software which update every now and then must be a pain in the ass. I understand it's too good Resolume plays Quicktimes and SWFs, but it was one of the points it convinced me to buy it, so...
In my old PC I could read Quicktime's MOV and flash's .swf without problems. Now I can't read MOVs, I have Quicktime 6.0... What Quicktime would I need??? I read the manual and don't find anything about versions of Quicktime. So I am not sure if I have to go up (6.3) or down (5.0)...
For flash I installed the new 7 plug-in. Resolume loads them OK, but once I play with them for a while, they don't work anymore, becoming white (they produce white instead of the flash movie)... I suppose that installing Flash 6 plug-in will resolve this??
It would be nice to have the exact version of each (QT and Flash) Resolume supports.
4) Resolution
So after years waiting to buy a notebook powerful enough, after all my ranting about VJing at 640x480, today I tried and switched the output to 320x240 (Scale to current monitor, which is 800x600, the S-Video output). I nearly had to swallow my own words, it looks too GOOD!!! I was reading the same 640x480 indeo 5.1 AVIs. And they didn't look bad at all. In some zones you can see a little degradation. Switched to 400x300, and it's looks too good. In my old 14" Sony, I can see some difference, but possibly not one that justifies the loss of speed of making Resolume work at 640x480.
My monitor is everything except broadcast, I am sure with a good monitor or going VGA to a projector, there must be a clear improvement in image quality, but it is nice to see how beautiful things may look with 400x300. I want to try to convert some clips to 400x300 and see if they play like the 640x480. And I want to try with a projector. It's not the same a 14" screen, than a 150"...
I even need to determine if I see a gain working at 32bits over 16bits...
5) DV artifacts
This is pretty serious. When connecting a DV cam to Resolume, I have a problem when the camera pans or the objects move. I first thought about interlace, but even with Deinterlace Freeframe plug-in (thanks SleepyTom!) and my camera in progressive mode, I have the same problem.
I can't include a picture, it doesn't work, since I don't know how to explain. When there is movement in the image, I see some lines.
I have to recognize that similar things happened when I converted some of my 720x576 MOVs to 640x480 AVIs... Obviously going from 576 lines to 480 produce some kind of artifacts. To resolve this, maybe the Firewire-In can be cropped, so you just throw away pixels. It should be adjustable though.
It would be GREAT to get rid of this artifact. Another great reason to buy Resolume was Firewire in...
6) Glitches
I keep looking at the output in my 14" Sony TV, and every now and then, I get very little glitches. It's the kind of artifact regular people never see. I noticed they appear when one clip changes. It's not a problem, but it would be better if they weren't there. I don't think they are related to the graphic card since they happen only when a clip change occur.
7) Level meter
I think there should be some kind of meter in Resolume. A kind of FPS counter. It would serve to measure the load of the system and start "mine is bigger than yours" debates in the forums...
8) In and Outs in parameters
OK, this is for Resolume 2.0. It would be great if effect parameters could have In and Out points just like clips have.
9) Closing Resolume
Sometimes Windows XP gives me an error. I think is a Windows issue...
10) The best
This is my list of things that should never change!!!!
- The "don't stop" output. I love that Resolume never crashes or stops to ask stupid things like "Do you want to check Resolume web site for updates?". Please, keep it like this. While trying resolutions and plug-ins I sometimes ended with combinations that slowed everything down, but they don't crash. Slow, even freezed output is much better than crashing!!!
- The simplicity. I understand there are a lot of things that could be added. But don't add them unless you can still keep the interface simple.
11) My wish list
OK, this is what I would like to have in the future:
- Firewire in issue resolved. Powerful computers and DV cams are cheap now. The firewire input is a big point in favor of Resolume, make it work 100%.
- Direct DVD reading. I read it in your web, it would be great!!!
- RAM loading option for clips.
- A freeframe plug-ins that load two freeframe plug-ins.
- Maybe two output effects. For example, the Levels in Auto mode is great to get a nice, bright image output. But if you use it, you can't load another effect...
- The top of the top: a Freeframe plug-in that loads AVS presets. This would be the top of the top. Imagine the inmense library of AVS presets available for any Freeframe app...
OK, end of my post. Sorry, it's way too long!!!
