IR mapio
VJair
Re: IR mapio
Post by VJair »
is that ^^^ the 10.5 script fix or to help my fault? ( if its for me, i cant get it to work - not totaly sure where it needs to go )
black_sire
Re: IR mapio
Post by black_sire »
VJair wrote:is that ^^^ the 10.5 script fix or to help my fault? ( if its for me, i cant get it to work - not totaly sure where it needs to go )
Yes, this is fix for MAC OS X 10.5.
For your problem see facebook.
irworkshop.com
VJair
Re: IR mapio
Post by VJair »
juLiE
Re: IR mapio
Post by juLiE »
VJair wrote:anyone running mapio on win xp?
Yes, I am and it works fine.
2013 - Present: Dell Inspiron 7720 laptop, Win 7 sp1, Nividia GeForce GT 650M
2008 - 2012: Dell Vostro 1700 laptop, Win XP sp3, Nividia GeForce 8600M GT
2004 - 2008: Mini PC ITX...
Official Website: http://www.juliemeitz.com
GeeEs
Re: IR mapio
Post by GeeEs »
Does anyone of the IRmapio users have experinece with the IRmapio 1.1 update?
On the site I read there is a restriction with blending. but.. It doesnt work at all in Avenue here. If I put opacity (of the plugin) to 100%, my output is black. Nothing to see. When I put the opactity on 99%, then i get a normal output, but without any effect of the plugin.
I see the editor, I can control all the parameters in the plugin (with some nice new features!!), but it seems that the plugin isn't doing anything...!?
Help!?
Stickygreen
Re: IR mapio
Post by Stickygreen »
black_sire wrote:For solving problem on MAC OS X 10.5.X.
1. Install IRmapio by default
check the location of files in the folder "/Applications/IR Mapio/"
2. Launch Avenue. Open the preferences dialog and select the "Video" tab.
add folder "/Applications/IR Mapio/" into the list of directories. Quit Avenue.
3.Download and unzip the attached file "com.irworkshop.Mapio1.plist.zip".
Move file com.irworkshop.Mapio1.plist to folder "<user>/Library/Preferences/"
4.Done. Launch Avenue.
very important fix here. applies to most Mac OSX 10.5.8 users
thanks for all the work on Mapio so far black_sire
DayVeeJay
Re: IR mapio
Post by DayVeeJay »
I also had issues with mapio freezing when it was in the "program files/resolume avenue/plugins/vfx". Deleting them and then adding "program files/irworkshop/irmapio" to the video fx preferences fixed the issue. Thanks for the tip!
