IR mapio
deepvisual
IR mapio
Post by deepvisual »
can't seem to get this to work on the mac.
I installed it - fine. v1.1
but no plugin in resolume?
I tried dropping the IRMapio.bundle into the same folder as all the other resolume effects and it came up in the menu, but crashed if I tried to use it..
any ideas?
vj granda
Re: IR mapio
Post by vj granda »
The better is to contact with Ivan, the creator of the software. He has a good and quick client service...
contact@irworkshop.com
deepvisual
Re: IR mapio
thanks
VJair
Re: IR mapio
Post by VJair »
probably a silly thought, but have you made sure its added the folder in the preferences / vfx folders?
deepvisual
Re: IR mapio
got to the bottom of it.
its only been tested on 10.6 - snow leopard.
seems it isn't working on 10.5
it works fine on my 'snow leopard' machine and not at all on the regular one.
G
Stickygreen
Re: IR mapio
Post by Stickygreen »
good to know DV, I've got Mapio working on my PC, but haven't even installed it on my MBP yet.
Stickygreen
Re: IR mapio
just installed and tried it on my 10.5.8 MBP, and I get the same thing as you did Deepvisuals, every time i load the IRmapio effect it crashed the resolume application. but if i open IRmapio in applications it opens, but it's useless cause it's not connected to the composition of resolume.
shouldn't have to upgrade to snow leopard for this should I ...?
black_sire
Re: IR mapio
Post by black_sire »
Apparently, does not work the script of installation IRMapio on 10.5.x.
This script is adding a new folder item to vfx preferences of Avenue, and sets the path for finding MapioEditor.
A little later (today or tomorrow) I'll write instructions on how to do it manually.
In a future release will decide the issue (I will need to find the installition of 10.5.x for tests)
irworkshop.com
VJair
Re: IR mapio
Post by VJair »
anyone running mapio on win xp? ( my win 7 machine is unwell, so i have to make do for the next gig :( )
avenue crashes when i load it, but i dont know if its a win xp issue or just an issue that can be cured by a windows update?
black_sire
Re: IR mapio
For solving problem on MAC OS X 10.5.X.
1. Install IRmapio by default
check the location of files in the folder "/Applications/IR Mapio/"
2. Launch Avenue. Open the preferences dialog and select the "Video" tab.
add folder "/Applications/IR Mapio/" into the list of directories. Quit Avenue.
3.Download and unzip the attached file "com.irworkshop.Mapio1.plist.zip".
Move file com.irworkshop.Mapio1.plist to folder "<user>/Library/Preferences/"
4.Done. Launch Avenue.
(750 Bytes) Downloaded 1434 times
irworkshop.com
