Got the same issue, different hardware.
Software seems nice, but can't use it 2nd screen.
Hardware:
AMD 64 XP3000+
1Gb DDR 400
ASUS K8V
Geforce FX 5900XT (drivers 61.77)
dual monitor bug in 2.0 Beta 2
Proplem solved
Problem solved!
Try playing a clip before turning on dvdMAX. By doing that, dvdMAX feature works fine (at least it works with my computers).
Thanks for Vj Aca for this tip, you are a lifesaver
