dual monitor bug in 2.0 Beta 2
levon
Post by levon »
first my computer specs,
athlon XP 2400+
asus mobo
geforce 4 ti 4200, with lattest drivers
ive recently just got an old digital projector, and tried hooking it up through resolume. but when i change the settings in resolume 2 to:
display 1: interface with preview
display 2: fullscreen
and click apply it crashes and i have to kill the program with ctrl+ alt+ del. i also tried this in resolume 2.0 beta 1 and have the same problem.
has anyone else got this problem?
any one know of a fix for it?
Anonymous
Post by Anonymous »
are you in clone mode ?
what is the version of your nvidia drivers ?
levon
Post by levon »
im using the lattest drivers; 61.77
and was doing it in ndualview mode, or whatever it is called. i dont have the projector pluged in at the moment so i cant tell you the exact name of it.
defje
Post by defje »
Hm, i didn't saw this topic, at least i forgot it was here.
I have the same problem as explained right here http://www.resolume.com/xmb/viewthread.php?tid=959
levon
Post by levon »
oh yes i forgot to say that im running service pack 1.
thats odd, both of us have quite different specs and they still crash :mad:
defje
Post by defje »
yeah, perhaps it's because of some software we're running?
Anonymous
Post by Anonymous »
Is your audio controller activated ?
It seems that resolume need at least one audio controller activated to work properly.
Mine was desactivated, i've installed it and now it work fine...
Danger
Audio controller activated
Post by Danger »
"It seems that resolume need at least one audio controller activated to work properly. "
At work i use linux and use a win2000 Virtual Machine to play with Resolume
In the VM i don't have audio activated and the dual monitor work fine
defje
Post by defje »
i can even use the audioanalysis so i guess that's not the problem for me.
levon
Post by levon »
yep me to, i use my computer for music as well as visuals, so it cant be that.
