I must solve this stuttering problem once and for all
Re: I must solve this stuttering problem once and for all
steve33 wrote:first i got a reply the says that this is a known issue and a software problem and now you are saind that there is something wrong with my hardware, i definitely prefer the hardware problem because that is something i can fix.
There are many of us using Resolume out there professionally and I can guarantee you there is no stuttering in the systems I built so even though it may be a known issue it's not like Resolume stutters by default!
No mixed messages here, we are all trying to help you figure out what's causing your stuttering issues so of course there will be many different suggestions and until you have fixed your problem you need to be appreciative of the time people spend trying to help you. It could be software and it could be hardware and it could be a combination of both but until you know exactly what it is it could be anything!
steve33 wrote:do you have a test sugestion i can make to make sure that is something wrong with my GPU?
You could try EVGA OC Scanner X (http://www.evga.com/ocscanner/) but my recommendation would be to try a different GPU as well as testing your current GPU on a different PCIe slot as it could also be a faulty PCIe slot with unstable power.
Are you overclocking your MB or your GPU?
What BIOS do you have on your GigaByte GA-X79-UD3 MB?
Then....
steve33 wrote:you can see the read speed on the right (510MB/s) and you obviesly dont know what your talking about.
it says that i cannot Write 1080 50P 12 bit RGB which is 550MB per second!
1080 25p DXV file is like 12MB per second, i can play 40 DXV clips at a time with my hard drive!
please do not reply if you do not know what you are saying.
I think you need to be a little more respectful of other contributors in your replies and assume senior contributors like dirtyjohn_lv know what they're talking about!
Here is what your Blackmagic Speed Test should look like when it has all the read information not just the overall Read speed at the top:
as you can tell your test is missing all the Read information! For instance, as per the last column on the right, my system can read 2K 12 bit 4:4:4 from my SSD at 45FPS.
This is a friendly and supportive forum and your posts have had a fairly consistent unpleasant and harsh tone so 1) consider yourself lucky people are still trying to help you and 2) in the future heed your own advice and please do not reply if you do not know what you are saying!
dirtyjohn_lv
Post by dirtyjohn_lv »
Another question, the clips you see stuttering in ... how are they created? Are they your own media that you create and export to DXV? Are they converted clips from another file type or framerate? What is your process for creating these clips that you see stuttering in?
Hi Steve,
thanks for the additional video you've made, but you recorded it with 30 fps. You cannot record a 25/50 fps stutter with 30 fps ....you need to record it with 25 or 50 fps...better 50. Otherwise there will be more stutters in the clip then there actual are.
What about the WIndows processes? Is your system back? I would like to see the whole list of processes while Resolume is playing back a testclip.
Best regards
steve33
Post by steve33 »
Oaktown wrote: There are many of us using Resolume out there professionally and I can guarantee you there is no stuttering in the systems I built so even though it may be a known issue it's not like Resolume stutters by default!
As a senior member wrote:
cosmowe wrote:Hi Steve,
first of all...you will not manage to reach 100% smoothness for now. The Resolume guys know that...and they are still working on it.It is an issue on software not on hardware side. But its possible to reach 95% with Resolume 4.2 ....they made a huge smoothness jump with 4.2
Oaktown wrote: No mixed messages here, we are all trying to help you figure out what's causing your stuttering issues so of course there will be many different suggestions and until you have fixed your problem you need to be appreciative of the time people spend trying to help you. It could be software and it could be hardware and it could be a combination of both but until you know exactly what it is it could be anything!
I am very appreciative and i saying again thank you and all other members for you help,
but looking at results of 500m/s and saying that i cannot play HD files is unprofessional and could be deceiving for other members reading this post. i stopped the test before it finished calculating the read data but you can still see the read speed and that is whats important, not the uncompressed files handling.
Oaktown wrote: You could try EVGA OC Scanner X (http://www.evga.com/ocscanner/) but my recommendation would be to try a different GPU as well as testing your current GPU on a different PCIe slot as it could also be a faulty PCIe slot with unstable power.
Thank you, i will try that
Oaktown wrote:Are you overclocking your MB or your GPU?
just the CPU
Oaktown wrote:What BIOS do you have on your GigaByte GA-X79-UD3 MB?
Latest bios and drivers
Oaktown wrote:Here is what your Blackmagic Speed Test should look like when it has all the read information not just the overall Read speed at the top:
The attachment Screen Shot 2015-06-16 at 06.44.01.png is no longer available
Oaktown wrote:as you can tell your test is missing all the Read information! For instance, as per the last column on the right, my system can read 2K 12 bit 4:4:4 from my SSD at 45FPS.
Ok, if you insist, here are the obvies results:
Thank you all.
I think i've got all the information i need to make my further steps.
resolume arene 5.0.4
i7 6700K
32GB RAM
GTX770
DeckLink QUAD 2
cvanhoose
Post by cvanhoose »
FYI
You can go faster (850Pros) raid0
I use 10k comps for shows frequently, with 10K layers.....no stuttering.
I produce all of my content and I am the operator. If the footage is rendered out at 23fps, then re-encode to 60fps, or higher than original, you will see stuttering. In that case it will be the content.
What is your final output? I run to an AnalogWay Acsender48 to 60hz HDX20 Barcos.
But he don't need to get faster....his read speed is fast enough. That's not the problem.
@steve33:
What about your System processes?
Something like this?!
In my case I can force stutters with some system load in background.
Another question to your BIOS...is any kind of eco mode disabled?
greetings
steve33
Post by steve33 »
cosmowe wrote:But he don't need to get faster....his read speed is fast enough. That's not the problem.
ohhhh finally!
cosmowe wrote:What about your System processes?
cosmowe wrote:Another question to your BIOS...is any kind of eco mode disabled?
There is no "eco mode" i know of
i7 6700K
32GB RAM
GTX770
DeckLink QUAD 2
John McGeoch
Post by John McGeoch »
As Cosmowe says this is a long time problem and effectively ruins Resolume as a classy deliverer of video in anything but Vj shows, where there is usually so much going on that you don`t notice it. For Theatre / Dance / AV shows it`s often a killer. Probably the most important thing needed with better sequencing show control. Great program but needs a new engine! Any news guys ?
dirtyjohn_lv
You do realize on the front page on the website it says "VJ software" in bold white text right? Made by VJs for VJs.
Yes, it can be used for other things and has grown to that. There is software much better suited for those purposes, Isadora, catalyst, playback pro, have you tried them?
There has been a HUGE improvement in performance since the 4.2 update ... I would normally run around 30-45 fps before, now I run between 60-100fps.
There are tons of variables that go into what could be wrong with your playback and without knowing specifics it's near impossible to let you know how to fix it. Posting that you have problems using the software other than its intended use and asking for a solution or update is not helpful to the post ....
That's like buying a 2 seat car, trying to fit 3 people in it and complaining there's not enough room, then asking manufacture when they are going to add a backseat.
Best thing you can do for those kinds of shows with Resolume is send the client a sheet with video render requirements (special sizes, codecs and any other info need). I've done this with a ton of corporate clients and successfully weened them off sending me H264 files and they either send me ProRes or DXV and they are completely satisfied with results
