Record problems
Hypnotist
Re: Record problems
Post by Hypnotist »
Tried with syphon recorder for same compostion and it works perfectly.
http://ljhypnotist.com
iMac 12.2, 3,4GHz/16GB/HD6970m 2GB/TB SSD-raid/DH2go
Arena 4, Modul8, Arkaos, MAX, QC, Unity3d, Madmapper
Launchpad,Maschine, RemoteZero SL, Bitstream 3x
Sadler
Re: Record problems
Post by Sadler »
From the manual:
If recording suddenly stops, this is because you have run out of memory. When recording, Resolume tries to write the rendered frame immediately. This is done at a very low priority, because you don't want this to interfere with the actual output. So when it's too busy (lots of effects/clips/pixels), it stores the rendered frame in memory, and tries to write it later. At a certain point, when the memory is 90% full, it will stop recording and write the remaining frames in memory.
If you want to record longer segments, you will either have to write to a faster drive, get more memory or lower your resolution.
