i have problems with recording,i press buton record and then i do some mixing,after 10,15 sec. my record its stop and start writing,but im not finish,how to set record setings to stop manualy,that i can press stop buton to stop,
sorry for my bad english,im from Bosnia so understand me
and i realy need this to work,this is the best vj program,so please help me,so i can continue with my work
Record problems
Re: Record problems
Perhaps your HD is full. by default resolume records to :
Mac: ~/Documents/Resolume Avenue 3/recorded/
PC: ~/My Documents/Resolume Avenue 3/recorded/
the recorded files are bigggggg.
Re: Record problems
no,i have a lot of space,20 gb free
Re: Record problems
i realy need to fix this problem,i want to record and to manualy stop recording,any sugestin its good,i will try everthing
Re: Record problems
how big is the recorded file? it could be that you are reaching the 2gb file limit if your HD is formatted in FAT 32
Re: Record problems
hmmm, strange. I'll do some test see if I can replicate the error. the record feature should keep recording until you hit the button again.
Re: Record problems
Sorry, but I don't have the same issue. I just recorded for 2:30 min and was able to stop the recording manually. My video as also only 200mb. So i'm a bit surprised that your video recording is 300-400mb if the length is only 10 seconds long. are you using resolume 3 or 2?
Re: Record problems
im using resolume 3.0.1,
my problem is i press record sometime it record a bit longer,and sometimes it stop after 10,15 sec,so i erase all file in record folder,also i change record folder,nothing
its random stop,and when it stop i can press record,and record again,but you can imaging what that mean when you do some staff
