Output flickering
KDLynch
Re: Output flickering
Post by KDLynch »
i'll try the no-preset tomorrow or next day here. also having same issue... oddly, it was getting progressively worse (flickering more and more frequently)... rtx 3070, running avenue, intel cpu. (i can get exact specs when in theatre next) ... the machine isn't on net, so hadn't updated (windows/graphics) it in a long time, so did updates (both windows, and manual nvidia drivers, no geforce/nv app stuff) a couple weeks ago, but no luck... still getting worse, and .much. worse two nights ago (as in every few seconds).
had venue order another projector, as what it .looks. like is similar to the dmd chip failing/not syncing correctly... but when trying a borrowed projector, with all new lines running to it, same issue. so back to computer... installed latest nv studio driver today, and frequency of flickers went .way. down (few minutes between, random timing, more common but not exclusive to brighter stills and dxv movies), but not completely gone.
so it does look like it's something in the nvidia driver that is being poked at, but not completely fixed... mayhaps something in the preset for resolume is exasperating the issue?
now that I have a few days until my next show, i will try the no-preset option (reinstalling same nv driver pack as i have in right now, after a full uninstall) and will report back.
at least if this works, then i'll have a good backup projector now. :) small theatres with tiny budgets... gotta love them.
KDLynch
Post by KDLynch »
I haven't done the reinstall (no-preset method) yet, I did get version numbers:
I went from Resolume 7.22.4 / NVidia Studio 572.83 (progressively worse flickering until it got really bad)
to Resolume 7.22.6 / NVidia Studio 576.02 (still flickered, but >much< less frequently than prior)
Both of the above installs done with manual d/l and install... I did not use the NVidia app. The 572.83 was installed after a complete driver cleanout (DMD? something like that)... 576.02 was installed over the 572.83 (normal upgrade procedure minus the app). A fairly current win10 is the o/s.
We do have a new (duplicate) projector on the way, and I will do the no-preset install after the projector swap-out... wanna make sure the infrequent flickers carry over to the new projector first (which I fully expect it to do)
brinkoko
Post by brinkoko »
Zoltán wrote: Thu Apr 17, 2025 19:08 Do a Custom nvidia driver install, and choose the Clean install.
Then igore the nvidia preset installation on Resolume startup.
7.23 will have the automatic preset install disabled.
Reiterating server's specs:
intel i9-12900KF (3,2GHz)
RAM 64GB
GPU: MSI RTX 3080 GAMING Z TRIO 12GB,
Windows 10 Pro 22H2
2 Displays: 1) 2560x1440 (performing), 2) 1280x1024 (control)
Did custom NVIDIA driver install from 572.60 to 576.02 (16/4/25) Studio driver, clean install, ignored NVIDIA preset installation on Resolume starting up dialog box.
No obvious flickering observed yet.
I'll come back with any news, if ever.
Thanks Zoltan :D
stvvisuals
Post by stvvisuals »
Zoltán wrote: Sun Aug 13, 2023 21:30
mr_angelback wrote: Sat Aug 12, 2023 20:36 What if there is something in some of the latest nvidia drivers that is not working correctly with the resolume software?
That's what we're thingking too, so would be worth trying out a Studio driver from 1-2 years ago.
It yet seems exactly what is happening, yet.i Also see that files in DXV rendered on later version of any of above, run faster and more frequent into this glitchy issue. And it is a very clean checkerboard pattern.
im running now on december 2024 versions witch have some difficulties. But at least the output stays stable
stvvisuals
When will 7.23 be released? It seems that this ignore setting resolves the issue, however I'm not very happy upgrading any of mu drivers / systems yet... (running 2025 January now)
blushift
Post by blushift »
I'm experiencing the same issues reported in this thread, and I’d like to share the results of the tests I’ve run on a machine that shows the same problems described by other users.
Here are the system specs:
Operating System: Microsoft Windows 11 Professional (x64) Build 22631.4751 (23H2)
CPU: Intel(R) Core(TM) i9-10980XE CPU @ 3.00GHz
Motherboard: ASUS WS X299 SAGE/10G
RAM: 32 GB
I’ve tested both an NVIDIA RTX 3070 and an RTX 4060 GPU.
The driver version used in both cases is Nvidia Studio 576.52.
Unfortunately, I encountered the same issues with both cards.
From what I can tell, it seems like Arena is failing to render some frames.
When running at 60 FPS, I experience the same type of flickering already described by other users.
However, if I force Arena to run at 25 FPS, the output becomes stable.
I also noticed something that might help developers find a solution:
If I set the Windows display scaling (in the display settings) to 125% or higher, the output becomes stable even when Arena is set to Auto FPS or 60 FPS.
Another thing I noticed is that if I open a Windows Explorer window while the output is running and then "shake" the window with the mouse, the flickering issue reappears immediately—suggesting it might be related to this kind of system interaction.
I have video recordings showing all of this, in case it helps clarify the situation.
I truly hope you can find a fix for this. Otherwise, we may be forced to stop using Resolume Arena, which we currently rely on in our company as a powerful media server for events.
Thank you.
